Tremec T56 Magnum XL transmission fluid
I have done allot of research on what fluid to use after the break-in using the dexron III. I have found it not only confusing but misleading in many case's and not founded on facts. So I contacted Tremec and specifically asked about the Tremec T56 Magnum XL.
Here's the answer I received from tech support today for anyone who needs to know.
"Quote"
Good morning Nick,
Thank you for your interest in the Tremec Product Line. We do recommend Mobile 1 Synthetic AFT and Pennzoil Synchromesh fluid for your application. Some people have a hard time finding one or the other but they are both good fluids to use in your application.
Regards,
Rob Sheppard
Aftermarket Customer Service
_______________________________________
X 3717
"Quote"
Good morning Nick,
Regards,
Rob Sheppard
X 3717
Dont use the gm synchromesh they recommend on their web site. After i break mine in with mobile 1 i'm switching over to this:
http://www.amsoil.com/shop/by-produc...?code=ATFQT-EA
Mobile1 synthetic ATF works well. I've also seen a lot of guys use Redline ATF with success. I don't think you could go wrong with either, plus it's nice to use exactly what the manufacturer recommends too.
BTW- I'm jealous of your T56 Magnum XL upgrade. Enjoy it!
Shane
Shane
Shane
Shane
That it is expensive, but you can't buy a better trans! Now you'll love the smoother shifts and the fact you won't have to worry when rowing gears. Which is important when sporting a positive displacement blower, like the E-Force.
Good luck with it!
Shane
Good luck with it!
Shane
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
