Sponsored by:
Sponsored by:
Inner Tail Light and License Plate Light Problem
Old 10-23-2013, 08:01 PM
Ronin83
Ronin83's Avatar
Default Inner Tail Light and License Plate Light Problem
Hi all,
This is my first post and I was hoping someone would help me out with an issue I'm having. I recently switched out my tail light bulbs to LED bulbs along with an LED bulb for my license plate light. I was testing them out when all of a sudden the inner taillights and the license plate light went out at the exact same time. I checked the bulbs and they are still working because the inner taillight bulbs all light up when I hit the brakes and the license plate bulb was tested in another socket. I did some research online and I think it may be some wiring from the sjb (smart junction box) since there is a cluster of wires that connect to those three lights in particular. I've included a before and after picture link so you can see the difference. If anyone has any advice please let me know. I'd like to try and fix this problem without having to go to the dealership. Thank you!!!
http://i565.photobucket.com/albums/s...683/photo1.jpg (Before)
http://i565.photobucket.com/albums/s...683/photo2.jpg (After)
Ronin83 is offline
Old 10-24-2013, 07:42 AM
mustangspotential
mustangspotential's Avatar
Judging by that, I would assume you are correct in that there is a wiring fault somewhere. Doesn't seem like it could be a fuse or a relay as it would control all the tail lights (though I could be wrong). And if you tried the bulbs elsewhere, that's obviously not the issue.
I would look into the wiring.
Sorry I can't be of more help.
mustangspotential is offline
Old 10-24-2013, 08:55 AM
Ronin83
Ronin83's Avatar
This morning when I went to go start the car it wouldn't start up at all. It made a clicking noise like the battery was dead. The radio and interior map lights still work though. I didnt have a chance to jump start it since I had to go to work so I took my wife's car. Anyone have any idea what's going on? I've read about the "battery drain" issue with the SJB and I'm not sure if this sounds like the same issues others have had.
Ronin83 is offline
Old 10-24-2013, 12:35 PM
Art161
Art161's Avatar
I think that an LED can visually appear to be "off," but might still be drawing current if there is a problem with the wiring to the LED.
Art161 is offline
Old 10-24-2013, 01:29 PM
Nuke
Nuke's Avatar
Here's the link that includes the wiring diagrams: http://iihs.net/fsm/?dir=1
Nuke is offline
Old 10-25-2013, 09:46 AM
kevinmalec
kevinmalec's Avatar
Any updates?
I do know the two inner lights and license plate light will NOT light up, unless you have the light **** turned the whole way to the ON position.
Sounds like your battery is dead.
Do you turn your radio off? I've read that some members experiencing battery draining issues due to their Shaker 1000 audio system.
kevinmalec is offline
JonnyBlazeGT
11-03-2015 01:10 AM
kdryan
08-21-2015 04:01 PM
inyadreems
08-21-2015 09:10 AM
philster0306
08-10-2015 11:33 AM
tmdm
08-07-2015 10:24 PM
Quick Reply: Inner Tail Light and License Plate Light Problem
