Sway bar options
Sway bar options
ive been looking on american muscle at their sway bars for the 2014 GT ill be getting in january.
they offer the eibach kit. Front and rear and all the bushings
they also offer the Ford Racing one. The kit looks almost the same but its about $25 cheaper.
anyone have any experience with either kit?
The only reason I went with Eibach over Ford Racing was for the fact that I already had Eibach Springs on the car and just wanted everything to match. You'll be extremely happy with either option!
Let me know if you have any questions or need some assistance in the near future, I'd be happy to help!
-Dan
I too was debating between the Eibachs and the Ford racing sway bars and I choose Eibachs. The rear and front bars in the Eibach kit are adjustable, on the FRPP version only the front bar is adjustable. The bars made a very nice improvement in handling and recommend them highly.
I'm running the ford racing sways on the performance package.. You've felt how they feel
If you want some solid sway bars, go with whiteline. They should have a warranty and there's nothing but good reviews about them, they're based in Australia and are about 10 years ahead in the suspension industry. However, The ford racing package would be a cheaper way to go
Lucky enough for us, we're an Eibach Master Distributor, also a Whiteline Master Distributor, and of course same goes with Hotchkis too, so we've got lots of great options for you here. Here's some info that should help out:
Whiteline:
- Built with the highest quality solid spring steel
- More effective than a hollow bar
- Built with chassis tuning in mind
- Offer 4-point blade adjustability
- Heavy duty-adjustable end links
- 4 point adjustable
- Includes Lateral Locks
- Heavy-Duty Adjustable End Links
- Made with solid spring steel
Hotchkis:
- Improved handling characteristics
- Dramatically improves steering and chassis response
- Increases stability
- Flatter Cornering
- Reduced Body Roll
- Increased traction through turns
- Easy bolt-on installation
- Lightweight, Durable 1.5" (38.1mm) Tubular Front Bar
- Lightweight, Durable 1" (25.4mm) Tubular Rear Bar
- Tubular Rear Bar 3-way (rear) 4-way (front) adjustable
- Greasable polyurethane bushings and heavy duty brackets
- Finished in durable anthracite powder coat
Hotchkis Front:
Hole 1: 45% stiffer than 5.0L
Hole 2: 65% stiffer than 5.0L
Hole 3: 85% stiffer than 5.0L
Hole 4: 105% stiffer than 5.0L
Hotchkis Rear:
HP setting 1 = 120% stiffer than 20mm rear
HP setting 2 = 160% stiffer than 20mm rear
HP setting 3 = 200% stiffer than 20mm rear
Eibach:
- Performance Tuned Sway Bars for Improved Handling and Reduced Body-Roll
- Perfectly Balanced for Optimum Neutral-Steering Handling and Precise Turn-In Response
- Precision Engineered and Calibrated for PRO-KIT and SPORTLINE Performance Spring Kits
- Precision Hi-Tensile Steel Alloy, Cold-Formed, Tempered and Shot-Peened for Long-Lasting Performance and Durability
- Greasable Urethane Bushings For Increased Responsiveness
- Precision Forged Ends and OEM Style Pressed Bushing Locaters (No Welding Or Weak Points Here)
- Million-Mile Warranty
- Bar Specs:Front Bar is 36mm, Tubular, 3 Way-Adj. / Rear Bar is 25mm,Solid, Non-Adj.
If you need help deciding, send me a PM!
Whiteline:
Hotchkis:
- Flatter Cornering
- Reduced Body Roll
Hotchkis Front:
Hotchkis Rear:
Eibach:
Steeda's running 10% off through the holidays
BMR is 15% off via Jason at Hypermotive Performance through the holidays
both great options
I personally think Strano Swaybars are top of the line so I recommend talking to Sam at Strano Performance
...just saying
both great options
...just saying
thanks for the help everyone. so it seems like the ony difference between the eibach and Ford ones is the colour, haha. and the adjustable rear.
i dont want to spend more than $450 but i will look into the whiteline and hotchkis ones also.
i just installed some racing beat swaybars on a newer Mazda Miata, it made the damn thing like a skateboard. it needed some wider wheels and tires!.
but i was blown away by the difference they made. thats what encouraged me to look into them.
I have $2,000 to spend on mods when i get my 14 GT and thats it for a very long time so im trying to see what i want to get,
so far i have on my list
CAI and Tune
Oil Catch Can
Roush Exhaust
Window tint
tint for all the amber lights and reflectors
and i have about $500 left so im looking into swaybars.
if anyone has any input on something i should buy insted let me know
CAI and Tune
Oil Catch Can
Roush Exhaust
Window tint
