Eibach sway bar crosover!
I have an opportunity to get used front and rear Eibach sway bars P/N 35115.32 for the GT500s
Obviously on American Muscle the cars have different part numbers and the Regular GT Eibach kit says it won't fit the GT500, but will the GT500 bars fit regular GT? The Rear
The front bar diameters are the same but the GT500's rear bar is a little bigger 24mm vs 22mm
TIA!
TIA!
TIA!
TIA!
In my experience, if the GT kit won't fit the GT500, I'd assume the GT500 kit won't fit the GT. However, if it doesn't fit because the GT kit is to Small for the GT500 then you may actually be able to use it! I'd recommend test fitting it before you purchase it.
Hope this helps at all! Best of luck.
-Dan
