Carbon fiber vinyl wrap for dash/interior....
#21
the radio section I pulled out of the car only 2 bolts after you pop up the arm rest. I removed the radio its just a bunch of screws on the back and wrapped it. the parking brake area is all 1 solid piece on the arm rest. I just used my heat gun heated it up laid it down some..heated laid down and so on till i got it all the way to the bottom and covered. that part alone took like 25min
#22
That looks really good! Ive personally never wrapped anything either soooo ill post up how mine goes as well hoping my wrap comes in the mail today along with my primer 94. Ima attempt the whole dash and console as well.
#23
i saw the speedo area just pulls out and can wrap that out of the car. the center section with vents just has bolts on each side. but to get the ones on the right you have to remove the airbag that has the trim attached to it on the pass side. I am kinda iffy about removing that one. but sure would make it a bunch easier to do out of car
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
