Sponsored by:
Sponsored by:
DTE FLI Data Error
Old 02-01-2014, 10:15 AM
Bwright
Bwright's Avatar
Default DTE FLI Data Error
I have looked all over this forum for help and non really apply to my problem. I was installing heated seats in my 2007 last weekend and after reconnecting the battery keep getting the DTE FLI error. I have had no problems will fuel or anything until this happened. Checked all fuses and relays, everything is OK. Any ideas short of taking it to the dealership?
Bwright is offline
Old 02-01-2014, 04:59 PM
edwin108
edwin108's Avatar
Have you tried disconnecting the battery for a few minutes?
edwin108 is offline
Old 02-02-2014, 06:33 AM
Bwright
Bwright's Avatar
Yes, more than once, it was also disconnected during the entire process of installing the heated seats as well.
Bwright is offline
Old 02-02-2014, 06:47 AM
RedFire281
RedFire281's Avatar
Check Fuse #19 in the SJB (Smart Junction Box - passenger side kick panel). Ford uses a slow blow fuse so it might look like it is ok but may not be if you look real closely. Change the fuse anyway and see what happens. Please update us one way or the other.
RedFire281 is offline
Old 02-02-2014, 08:54 PM
edwin108
edwin108's Avatar
Does the car start and run? If not, your fuel pump safety switch could be tripped.
edwin108 is offline
Old 02-03-2014, 08:46 AM
Bwright
Bwright's Avatar
I really was hoping that Fuse #19 was the problem, however, the fuse tested good and I did replace it but still have all the same problems.
Yes, the car runs. Still have the DTE FLI error code, convertible top will not go up, Oil and fuel gauge doesn't work as well as the instruments lights for the airbag and traction control stay on.
I drove the car about 15 miles yesterday and it never reset.
Any other ideas before I take this car to the dealership?
Bwright is offline
Old 02-03-2014, 08:58 AM
Bwright
Bwright's Avatar
Any chance I can reset this code with a OBD2 scanner or does disconnecting the negative terminal on the battery do about the same thing?
Bwright is offline
Old 02-03-2014, 12:21 PM
edwin108
edwin108's Avatar
Did you loosen any harness ground bolts when you installed the heated seats?
edwin108 is offline
mrtrodonet
09-19-2020 03:12 PM
piotrek53
10-13-2015 06:54 PM
TCStangerv6
10-11-2015 05:57 PM
10-07-2015 07:02 PM
Quick Reply: DTE FLI Data Error
