lots of new stuff on the way.
#21
Beg to differ, my Steeda Pro-Actions, mated to the sport springs, is different. The Pro Actions were a bit smaller, and the valving is obviously different. IMHO its best to keep same brand suspension parts together, or ones proven to be compatible (I.E. the Tokico D-Specs which Steeda also sells).....
#22
#24
I have the Eibach Pro-Kit springs now, and have been waiting to install until I have enough saved to purchase Shocks/Struts and C/C plates. It sounds like you didn't install C/C plates an had no issues with alignment? Right now I have enough saved to purchase Shocks/Struts and could install sooner if I don't need C/C plates. I have adjustable panhard bar installed already.
#25
#26
I bought the camber bolts ,but didn't use or need them . I have the SR performance springs from american muscle . I kept the stock dampers and struts since the car only had 750 miles on them when I lowered it. Its a 1 1/2 drop front and back .I drove it for a week and was happy when I took it to alignment shop. Everything was ok and no adjustments needed.The car rides awesome just stiffer than stock . I did alot of research and there are several people who have had the same experience with little or no adjustment needed !!
#27
I stand corrected...I had to go find my alignment sheet.The camber was fine ,but they did make an adjustment to left toe.It was at 0.00 and after set to 0.11 everything else was fine. Specified range is 0.00 to 0.20.. Sorry for the misinformation...So minor adjustments needed..
#28
10-01-2015 05:13 PM
