Sponsored by:
Sponsored by:
2006 gt with saleen supercharger need help, im lost
Old 03-17-2014, 08:18 PM
joeydenney7
joeydenney7's Avatar
Default 2006 gt with saleen supercharger need help, im lost
ok so i have had this 06 gt for about 2 years. drove fine , my buddy took it over a curb and all hell broke loose. first was fuel pump, replaced that and rims from curb accident. then i had to get a new battery, got a red top, which was a terrible idea, finally got that switched but after that it sat for about 7 months ( im in the military) i ran the bad gas out of it but it kept starting and dying, i though it was bad gas, but after that it would run for about an hour then go to failsafe mode and die. then it would crank sometimes but not others. fuel problem clicked the engine just wouldnt turn over. no codes on my sct tuner. i filled it back up and got on highway it got an hour down the high way when it died again. got it towed and it is at shop now. it has four codes P0102 which is a MAF low input. P0171 and P0174 which is system lean in banks one and two, that is from the tune im assuming, and P2106 which is TAC sys forced limited power. my question is what do i do, shop is a little ma and paw shop and the ydont want me through money at. i need help, any ideas or thoughts would be helpful. thank you
joeydenney7 is offline
Old 03-18-2014, 02:40 AM
outceltj
outceltj's Avatar
alternator can cause gremlins in these cars. do you have a stereo system in your car. You call the person that tuned the car for the supercharger. they maybe able to help.
outceltj is offline
Old 03-18-2014, 04:23 AM
bryan67
bryan67's Avatar
check your frame and under damage for wire loom damage. You mentioned going over a curb. Frayed or damaged wires can cause all sorts of codes. then with the codes you got i would start with the MAF code. Do some basic tests like mentioned above . Alternator, Spark, fuel pressure,etc. may have to start with the basics and try and catch it when its failing.
bryan67 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: 2006 gt with saleen supercharger need help, im lost
