V6 transmission interchangeable with V8?
I was curious because they are both borgwarner/tremec and thought it would be possible they could have the same pattern on the gearbox.
I am building a cologne 2.9 with turbo and about 450whp which has the same bolt pattern as the 4.0. But I think the T5 is bit to weak, especially since they are quite expensive to buy here and not that common. It will probably be a bmw gearbox instead with adapter plate.
