Sponsored by:
Sponsored by:
fuse box question combining fuse 12v sources
Old 07-30-2014, 10:19 AM
mustang283
mustang283's Avatar
Default fuse box question combining fuse 12v sources
okay i need a 12v switched source for my head unit, i want it on when in ACC, the on position, cranking, and started. apparently no fuse provides this. i found acc on, on is on, started is on, but when cranking it turns my head unit off. then i found one that is on when on, cranking, and started. but not ACC key position. can i combine these 2 fuses so it will provide 12v in everything but off? as in just running a jumper kind of from a side of both fuses? i just dont want my radio to shut off when cranking!! both fuses are pretty petty, pass. air bag indicator and heated seats that i dont have.. thanks!
mustang283 is offline
Old 07-30-2014, 02:59 PM
mustang283
mustang283's Avatar
bump. plz help someone lol
Old 07-30-2014, 03:23 PM
mustang283
mustang283's Avatar
im guessing if i hooked both fuses together it would just give the one without (key:acc) power that didn't originally have it? which wouldn't be a problem. i just need a 12v switched source for my radio with accKey, on, cranking, and started. and i would try it but i don't wanna create some short circuit. if my op doesn't make sense i can draw a diagram
Old 07-30-2014, 03:32 PM
bl817
bl817's Avatar
not sure why your going to all this trouble to bypass the switched wire in the radio harness.
bl817 is offline
Old 07-30-2014, 04:03 PM
mustang283
mustang283's Avatar
i thought there wasnt one in the 2014 harness
Old 07-30-2014, 04:26 PM
mustang283
mustang283's Avatar
http://www.moddedmustangs.com/forums...s-adapter.html
post number 4 and 6
Old 07-30-2014, 04:34 PM
mustang283
mustang283's Avatar
and i went right to fuse 28 in the fuse box, this is the switched 12v in the harness. and it did not work. The reason might be in this thread i think http://www.carstereo.com/forum/showthread.cfm?tid=61601
Any mustang techies out there in car audio/electrical?
Old 07-30-2014, 06:20 PM
jz78817
jz78817's Avatar
there hasn't been one since at least 2010MY. The radios now wake up via CANBus messages.
this is normal behavior, even on the older factory head units which still had a hard-wired ACC line.
jz78817 is offline
Old 07-30-2014, 06:55 PM
mustang283
mustang283's Avatar
first I tried hooking those 2 together, what happened was the acc fed into the fuse without the ACC and everything was fine, except when i turned the key off, it would go to accessory (key) and still be started, then to turn the motor off i would have to turn the key to the off position when it normally goes off in ACC. so that was not good. So i checked every fuse again, and missed the one for delayed accessory lol and now it stays on till i open the door after the key is out. It is how the factory head unit was now. I just wish it didnt turn off when cranking, but i guess i can deal with it.
Other issue is the illumination wire. The best i could get was 12v to the illumination wire whenever the headlight switch is on, which is fine, but i like to leave it on auto, and when i leave it on auto, that wire i have the illumination wire hooked to is live regardless if the top light sensor turns the lights on or not. So in order for the illumination feature to work I have to operate the headlights manually. I couldnt find any wire in the headlight harness to supply 12v when the autolamp turns the headlights on, and no 12v when it picks up light. I guess I have to go to another harness for that to work.
I just want to get it to as factory as possible lol
Old 07-31-2014, 06:26 PM
jz78817
jz78817's Avatar
that's how most cars with a hard-wired ACC line to the radio work. the OE radio in my Ranger did that, as does the Alpine 2-DIN I replaced it with. your starter needs hundreds of amps to crank the engine, so unneeded accessories get turned off until you release the key from CRANK.
jz78817 is offline
unit91
09-15-2015 09:53 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 04:12 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: fuse box question combining fuse 12v sources
