holy crap i almost crashed
Just got home from airport, decided to have some fun on the way and hear my roush wot for the first time. Cruising at 80mph floored it and car violently jerked to my left, it scared the crap out of me. At first i thought was a slick spot on the road, so i tried again same thing happened but this time i was more prepared. Im thinking its alignment problem since traction light didnt come on. It would of been very unfortunate if i did lose control..... Guess i have to vist an alignment shop tomorrow.
Tire that is worn unevenly or conical can cause it.
If you're only feeling the pull under acceleration I'd guess it's more likely a worn suspension component than alignment. Alignment you'd generally notice some all the time. Under acceleration you're shifting weight on the suspension which is where you'd notice a worn bushing or something.
Tires seems fine except for slight feathering. Theres a slightly left pull under normal driving too. Its not bad but under wot its violent. I think its alignment issue. Tire kingdom dont display caster, im wondering if i knocked it out spec when i hit the big pot hole a month back
methinks the OP is exaggerating just a bit.
im not.... it was a very violent jerk to left. It felt like someone yank my steering wheel soon as i floored it. Traction control light didnt come, im assuming its my alignment. Im getting it checked out in a hour.Suspension shouldnt be worn already since its a 13 with 12k miles.
