Sponsored by:
Sponsored by:
PA Performance Alternator price
Old 11-19-2014, 08:26 AM
CMcNam
CMcNam's Avatar
Got the infamous "Check Charging System" notification, switched to a PA Performance Alternator and the accompanying wire harness and haven't had a single issue with it since.
CMcNam is offline
Old 11-19-2014, 12:04 PM
Soldier GT
Soldier GT's Avatar
Well I guess we all see PA performance is kind of a hit or miss. Some have had luck and some have not. The real issue that I had was with the customer service.
Soldier GT is offline
Old 11-19-2014, 12:32 PM
Goldenpony
Goldenpony's Avatar
Well, my alternator should be delivered today. I hope to install it next day or two. Hope I am one of the "hits". We'll see.
Goldenpony is offline
Old 11-19-2014, 03:30 PM
americaniron
americaniron's Avatar
Originally Posted by cruisin5268d
Why should they take it back if it was outside the warranty period?
This is why. Life time warranty. Read the fine print, and you can see how difficult they can make it.
http://www.paperformance.com/scripts...a.asp?extra=18
When I finally got through to them all they seemed to want do is find excuses or possible circumstances as to how to deny the warranty. They were going out of their way to turn me down. Like I said in my post, it was brand new in the box. Good customer service is not their strong point
americaniron is offline
Old 11-19-2014, 03:31 PM
07BLACKGT
07BLACKGT's Avatar
I'm sure you'll be fine. I haven't had any battery or charging issues since I installed mine 2 years ago. The car always starts up eagerly now. Only beef I have with it is that it doesn't have a clutch pulley, so it squeaks when the car shifts hard 2-3 and 3-4 (tuned auto)
07BLACKGT is offline
Old 10-04-2015, 12:03 AM
barta5088
barta5088's Avatar
I sold my 06 gt stang to a friend. Has 59k miles, c&l race intake, PA performance 200 amp alternator, brand new battery, charge motion delete plates, tune from BAMA and a few other things. For some reason the battery indicator on the dash keeps going up and down and will eventually the headlights will start flickering on and off along with the dash lights. The alternator and battery have been tested, alternator is at 14 amps and the battery is brand new. Checked all connections to make sure they are not loose or burnt in any way. The alternator cable was upgraded to the larger cable to handle the larger alternator as well. Made sure the correct tune is on the car as well. When this happened the next morning the car was completely dead. Had the battery recharged and would last about 50 miles before the battery indicator started to fluctuate again. I have no idea what is going on. Does anyone know or have any suggestions.
barta5088 is offline
Old 10-09-2015, 10:03 PM
jpplaw
jpplaw's Avatar
Originally Posted by barta5088
Has 59k miles, c&l race intake, PA performance 200 amp alternator, brand new battery, charge motion delete plates, tune from BAMA and a few other things. For some reason the battery indicator on the dash keeps going up and down and will eventually the headlights will start flickering on and off along with the dash lights. The alternator and battery have been tested, alternator is at 14 amps. . . .
A 200 amp PA should be putting out way more than 14 amps, even at idle
jpplaw is offline
Old 10-11-2015, 09:20 PM
cema93
cema93's Avatar
I got the SR alternator for my 89 fox. Works fine. Make the upgraded power wire yourself. No sense in spending $60 on a wire with a fuse.
150 amp SR alternator = $200
cema93 is offline
Old 10-12-2015, 12:10 AM
Murphdog
Murphdog's Avatar
I also got the SR Performance 150 amp alternator for my '08. Works great!.
Murphdog is offline
Old 10-12-2015, 09:06 PM
outceltj
outceltj's Avatar
I have PA that was added to my b302 build. I drove it a bit and on the track. Took it back to brenspeed for a few other things to be done. My dad picked up the car and notice the charging light on in the car. He took it back to brenspeed and they replaced it free of charge. Other than that mine has worked fine and its been on for a about 2 years now
outceltj is offline
Quick Reply: PA Performance Alternator price
