Sponsored by:
Sponsored by:
Old 10-22-2015, 06:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Clicking noise under dash: Defrost door actuator
Old 10-29-2015, 08:12 PM
2007CalSpec
2007CalSpec's Avatar
Originally Posted by pnichol2
so I had clicking in my fuse box. Mechanic came out and ran a diagnostic test, said my air con actuator was faulty. I removed all four of them, clicking stopped (when I removed the relays as well), all four hock up to a battery and run fine. Thoughts?
I would open each one up and check for broken teeth. They may run fine hooked up to a battery and there's no load or torque on them but may click when reinstalled.
2007CalSpec is offline
Old 12-03-2015, 04:15 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I Never did post my source, sorry. Here it is.
It's from justanswer but it's from the Ford Workshop manual:
http://ww2.justanswer.com/uploads/ke...035508_act.pdf
Derf00 is offline
Old 12-12-2015, 02:17 PM
6-Speed
6-Speed's Avatar
Originally Posted by Derf00
1.Remove Smart Junction Box (SJB) fuse 10 and 12 for at least one minute.
2. Turn the ignition switch to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
3. Remove the key
4.Reinstall SJB fuse 10 and 12.
5. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct actuator operation.
I did this when my vents got stuck on defrost one morning. They would not adjust to any other setting and there were no clicks. Fixed it after the second try.
Is the Smart Junction Box the same as the passenger compartment fuse panel?
6-Speed is offline
Old 12-21-2015, 01:24 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Yep, the one that's in the passenger side kick panel.
Derf00 is offline
Old 01-28-2016, 09:30 AM
leerodgers1
leerodgers1's Avatar
Default Acuator 2009 mustang
I changed out the blend door actuator and the clicking stopped for 2 days and then started back but different. Clicks 6 - 10- times and stops and then starts again for 5 or 6 times. I read after this that it needed to be calibrated. I did that last night but it didn't help. Did I screw up the new acuator and need to get another?
leerodgers1 is offline
Old 01-29-2016, 11:11 AM
steven566
steven566's Avatar
Hello,
I'm new to this forum and I appreciate all of the great info here!
I have a 2009 GT Convertible that has some sort of actuator door problem as described by the others above. My issue is that it doesn't click anymore, and I didn't identify which actuator was the issue in time.
These are the symptoms:
1) The a/c system is working, but cold air is not making it out of the vents. This is the main problem.
2) I can adjust the temperature from hot to cold, though cold isn't cold. It seems as cold as the temperature would get without a/c to cool it down. I'm in Arizona, so even during the winter, the car gets pretty warm while sitting outside at work.
3) I can switch between the various positions with no issues (floor, vent, combined, etc. I rarely use defrost, but I believe that is working, as well.)
Another thing that may help is:
What used to happen is that the a/c would run (compressor on, lines cooling, etc.) but the air coming out of the vent was warm. Then, when I shut the car off and began to investigate the engine, and then turned the car back on, the a/c would then be blowing cold.
I'm thinking this must be due to the homing routine that the vent doors go through when the car is started. This procedure doesn't work anymore, which is probably why I don't hear the clicking noise anymore.
I'm still don't know which actuator controls the door to the a/c evaporator. Is it that the hot cold blend door is not making its full travel and staying biased toward the warm side, or is there a door just for the path that blows air part the evaporator. Or something else?
Is this enough info for someone to identify which actuator is broken and what part number I should get?
Thanks for the help!
Steve
steven566 is offline
Old 05-10-2016, 08:34 PM
roadpilot
roadpilot's Avatar
Originally Posted by Elcameeeno
I replaced the same actuator as the OP last year. Now it sounds like I have several clicking. Does anyone know how many total actuators there are and the associated part numbers? (616A & 616B?) I think there are three but am not sure. I am thinking I will just replace them all and be done with it for a little while anyway.
Jon
How many? Depends on if you have a single zone or dual zone HVAC.
1 - Inlet
1 - panel/defrost/floor
1 - blend temp
1 - 2nd blend temp if you have a DZ HVAC
roadpilot is offline
Old 09-10-2016, 05:19 PM
techdawgy
techdawgy's Avatar
There are actually 4 actuators:
[SIZE=6pt][SIZE=2pt]Mode Door Actuator - Air Inlet Door[/SIZE]
[/SIZE][SIZE=6pt][SIZE=6pt][SIZE=2pt]Mode Door Actuator - Defrost Door[/SIZE]
[/SIZE][/SIZE][SIZE=6pt][SIZE=2pt]Mode Door Actuator - Panel,Floor Door[/SIZE]
[/SIZE][SIZE=6pt][SIZE=2pt]Temperature Blend Door Actuator[/SIZE]
[SIZE=2pt]
I just did 2 of these, and yes, the top screw on the defrost door actuator is a major PITA!
[/SIZE][/SIZE]
techdawgy is offline
Old 09-10-2016, 05:27 PM
techdawgy
techdawgy's Avatar
[SIZE=2pt] Air Inlet Door Actuator,
Defrost Door Actuator,
Panel/Floor Door Actuator,
(Was trying to put links in last post, came out garbled... but links work) lol
[/SIZE][SIZE=6pt][SIZE=2pt][/SIZE][/SIZE]
jerrytubes
10-23-2015 12:11 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
Quick Reply: Clicking noise under dash: Defrost door actuator
