Sponsored by:
Sponsored by:
limiting factor on spare tire distance?
Old 01-11-2015, 02:32 PM
kevsgt
kevsgt's Avatar
Originally Posted by Norm Peterson
It's much preferable to avoid using different diameter rear tires on the drive axle - and especially if your car's differential is a limited slip type. All of the differential gears will always be turning more than they should, and the LSD's clutch plates will be continually slipping against each other (and wearing out).
Thanks for the thoughts. I'm waiting for the Ford dealership to get back to me about price for a new donut or tire, which I likely will get to be safe, as I plan to keep this car around a lot longer. I'm curious if checking wear of the clutch plates is something they do with their regular inspections every 5k miles, or only at larger mileage intervals, or only if something fails?
kevsgt is offline
Old 01-11-2015, 05:20 PM
Norm Peterson
Norm Peterson's Avatar
I doubt they check that. No way are the going to open up the pumpkin (and change the fluid at $xx.xx per quart on their nickel), and I doubt that checking one wheel for "breakaway torque" would be a good enough indication to be worth the trouble.
The way most people discover that LSD plates are worn is when they start having only the right rear tire spin on a hard launch or too easily when turning a hard right from a full stop. I'm not at all sure how wear on a Torsen type of differential can be gauged, other than by driving and observing.
Norm
Norm Peterson is offline
Old 06-23-2015, 11:28 PM
Art161
Art161's Avatar
Were you able to get a new donut tire? I think the size you need for the 17" wheel is T185/60R17, part number 9003089397.
From what I have been able to find out, this part has been discontinued. If anyone knows where to get such a tire (new, not sitting around for years), please let me know. Thanks.
Art161 is offline
Old 06-26-2015, 12:54 AM
kevsgt
kevsgt's Avatar
i got the tire on eBay, then had the dealership install it on my existing donut/rim.
kevsgt is offline
Old 06-27-2015, 04:16 PM
danzcool
danzcool's Avatar
Why are you guys overthinking this? The spare tire in my mustang is a 185/17R60 tire, you should be able to get one of those from any tire shop, plus you should be able to get it speed rated.
I agree that the limiting factor is both the tire age and the speed/load rating. Get a real tire on the spare rim.
danzcool is offline
Old 06-27-2015, 04:39 PM
Norm Peterson
I can't even find 185/60-17's online just to find out if it has the same load index as a T185/60-17 tire. I have my doubts regarding load capacity, as T-spares are typically inflated to much higher pressures than normal road tires (which are either SL or XL).
Originally Posted by TireRack
We found (0) tires for: 185/60-17
Originally Posted by DiscountTireDirect
No Results Found
We currently show no products available that match the size that you entered.
Originally Posted by VulcanTire
Sorry, the tire size 185/60R17 was not found in our catalog at this time.
Click here to Perform a New Search
1010tires won't even try to search for that size, doesn't list 17" diameter once you've entered 185 for width and 60 for profile.
Norm
Old 06-27-2015, 08:34 PM
Art161
Art161's Avatar
Thanks, Norm.
Art161 is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
firehorse02
11-16-2015 11:28 AM
KingRando
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: limiting factor on spare tire distance?
