Rubbing With 275/40/19 Rear on Lowered 2012?
I just installed the Steed Sport springs on my 2012 GT. My next change is new wheels and tires, and was able to pick up a set of Boss 302 wheels for $600. Im not keen on the stock Boss 302 tire size and would like to go with a 275/40/19 in the rear. The only thing I'm not sure about is if this size would rub since the car is lowered? Anyone have experience with this, or advice.
Front boss 302 wheel specs:
19" x 9" wide
5-lug, 4.5" bolt circle
169.3mm backspacing
42mm offset
Rear Boss 302 wheel specs:
19 x 9.5-in.
180.9mm backspacing
45mm offset
19" x 9" wide
169.3mm backspacing
42mm offset
19 x 9.5-in.
180.9mm backspacing
45mm offset
My 305/45/18s rubbed, I had Eibach pros on. Switched them out to GT500 springs and trimmed off about 1/2". WOrks just right now.
I would be more concerned with the height of the tire. It will be close but I think they should tuck right in.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
