HELP PA Performance Alternator leads to problems..
My car only has 45000 miles on it I'm nervous about replacing the plugs I've read bad things. My friend who works as a technician for Ford sent me instructions to test the connector for power and ground first before replacing the coil. I'm going to use an OEM coil.
I guess I'll try testing it this weekend, and if it has power then I'll replace the coil. I'll then start it and test the alternator while the car is running.
You DID DISCONNECT the negative battery terminal BEFORE you swapped out the alternator...yes? If not you could have damaged the PCM or another component in the process (thus the shocks now).
If it's a coil buy the Ford Motorcraft coil, don't buy a cheap knock-off. They cause more headaches than they fix.
The battery was disconnected before alt was swapped out.
Update : I bought champion 7989 plugs. And a new ford coil. The car runs great with the original alternator and a new coil on the first cylinder. (Didn't have to replace plugs at all)
Alex from American muscle posted a reply to me stating that they would either replace the alternator for me or set up a refund, whichever worked better for me. I contacted customer service at American muscle and the only thing they said was I would have to deal with PA performance directly.
So I sent a private message to Alex who replied to this thread stating this information at least a week ago and I have yet to hear back from him.
I have spent a lot of money with American muscle and I'm not happy with them right now !
Hey Op - Sorry to hear about the trouble that you're running into here and Wog beat me to it on this - Before going on a wild goose chase looking for x, y, and z I would start with your coil and then head back to the drawing board. If for any reason you're thinking after this that the Alternator is the source of the issue try to have the car limped to a shop locally for them to get a look at it! In the event that it's the Alternator we'll get you a replacement shipped out and delivered overnight to get you back on the road!
Keep us in the loop on what's going on!
Alex
Alex
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
mungodrums
Suspension
09-24-2015 10:12 PM
