Removing Sound Tube - wow
Got my set up from Blowfish 2 days after I ordered it so a solid 'A' on customer service. The kit consisted of a flat plastic plug for the firewall and then the rubber cap & a clamp for the CAI tube section. I gotta admit I was a little disappointed in the rubber cap; I expected it to be a touch thicker & am a tad concerned about long-term durability.
The install took all of about 4 minutes. Unbolt the one bracket w/a 10mm wrench, pull the hose out of the firewall, then disconnect the hose attached to the CAI tube. Pop the cap into the firewall, slip the clamp/rubber cap over the extension where the tube plugged into the CAI & tighten her down- blammo, done.
For those stating it had no effect other than appearance, I gotta disagree. Keep in mind I've got a Steeda CAI so that may be where the difference occurs but in my '14, the interior sound is most definitely quieter, at least by 2-4 decibels. Certainly noticable to my ears.
Is it worth the $13 +/- I spent? Well, I didn't have to drive to the hardware store, figure out what size to buy, & what to buy so that saved some time & effort. The parts from Blowfish probably cost $3 total but it was quick & easy and they did supply lovely directions. You gotta decide if it's worth it to you.
Overall, I'm pleased w/it & if the rubber cap lasts a long time, then even better. It does clean up the engine bay appearance a bit too.
Lee
Lee
LOL...She still has to approve them though...I did order the painted tail light trim from AM. After that, most of them are big ones. Driveshaft and 3.73 gears, Wheel and tire kit, Hood and paint job... we will be poor for a while
Quick follow-up to confirm my earlier post: drove the car all day & it's absolutely, positively quieter inside the car. The sound of the CAI sucking air is greatly diminished. I can actually hear my radio & bluetooth now.
Lee
Lee
No, sure don't but it does clean up the engine bay a bit on the driver side. No more long tube running along that side. And in my Stang's case, it really did make the interior quieter. I'm surprised by how much quieter it is.
Lee
Lee
BEFORE:
CURRENT:
EDIT TO ADD: I didn't notice a lick of difference in the noise after removing the tube. In my opinion, it's a worthless gimmick that sounds good on paper. The engine bay looks soooooooo much better without the tube though. And here is a tip: the kit I bought came with a silver in color hose clamp to hold the rubber plug on the intake tube; I replaced it with a black zip tie to make it look a little nicer (all black). I got my kit from CoolTech LLC (A small specialized place that is probably just helping somebody fund his hobbies a little. You'll see what I mean if you check out the parts he offers and for what vehicles.). Here is the link to the kit: http://www.cooltechllc.com/ford-boss...pe-delete.html
