Nitto NT05? Falken RT-615K?
Anyone running Nitto NT05's in sizes 245/40-18 front & 295/40-18 rear? My wheels are 18x9/18x10. Just wondering how the 245's will look on a 9" wheel. My current tires are NT555 in 255/45-18 & 295/45-18. I want something stickier. My other tire choice is the Falken RT-615K and it's available in 245/40-18 & 255/40-18 along with 295/40-18. I prefer the NT05 but it sucks that it's not available in 255/40 or even 45. Thoughts?
I'm running the Falken's, they stick when warmed up. I was actually surprised that when warmed up they hold all the way through 3rd while putting down over 900 to the rear wheels... 1st and 2nd not so much, but I just short shift through those. Have no experience with the NT05s.
295/40R18's rear, 255/40R18's front. I try not to drive in the rain due to my cold air intakes being low to the ground just inside the wheels. I don't think I'd trust them in the rain for much grip simply because there is so much contact, they are almost slicks, but I have driven them is the rain on the highway, probably halfway from LA to the bay area when the rain let up. A little bigger view of the tires/wheels.
2014 DIB 3.7 w/ sport shift "Blue Cyclone"
I run 275/40/18's rear & 255/40/18 front and like the gear help a lot since I have the 2.73:1 gear. Mine are Yokohama, wide tire's will hydro-plane, ask me how I know.
If RT615K's are anything like their earlier non-K version, they will be better in the wet than their tread pattern and tread block size suggests . . . at least for speeds under about 60 mph (I used to autocross on the 615's, and they were surprisingly good on wet days). However, they will heat-cycle out before they wear out, meaning that you'll gradually lose the nice extra dry grip that they have initially.
OP - if you need good wet weather behavior and can get past availability and budgetary hurdles you might want to consider the Michelin PSS.
The right wide tires don't have to hydroplane under most circumstances, including up to nearly an inch or so of water depth. Think WOT in 3rd, leading throttle on corner exit, and 110+ down the main straight at the end of the video when I could actually see the whole straight (around 11:00 you'll see how that managed to happen, but watch a couple of the early laps first). Just for you, Al, 285/35-18 MPSS all around absolutely do beat the OE 235/50 KDWS, at any wet driving speed, and are more than likely better than whatever Ford has provided in 18" GT sizes since.
Norm
Norm
Abbreviated Wet Session with 285 35 18 Michelin PSS - YouTube
Norm
Norm
http://www.steeda.com/blog/2015/09/s...ting-nt555-g2/
Galactic
04-29-2019 02:56 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
09-17-2015 07:32 PM
09-08-2015 11:50 AM
