Radio doesn't turn on
About two years ago the radio just stopped working. It had intermittent problems for a short while before it stopped working. Fuses were fine. The word Mustang and the temp worked fine.
Last week the battery died. I attempted to replace it with another I had only to realize the posts were opposite so I put the old battery back in and jumped it off. The radio came on and worked great. Then I replaced the battery with a new one and the radio is back off.
No button does anything but the temp works fine as well as saying Mustang as if radio were turned off.
Some radios have their own dedicated fuse on the back or in the wiring harness. Pull the head unit out and check for power.
Well, that's interesting. Sounds like a loose connection, which might have loosened up even more. Make sure you check your grounds, too.
I would put the old battery back in again and see if the radio comes back after jumping again. If it does, I really don't know what to say, but I would say your radio is not the issue. Maybe the new battery isn't putting enough amps? I am not sure what one battery over another would cause.
kdryan
08-26-2015 05:54 AM
