Help me with 2007 Shelby gt
A few weeks ago Driving I went to slow down pulling up to an intersection and the car stalled since then it's happened multiple times I cleaned the throttle body and changed the air filter Also the car has 64000 miles so I changed the fuel filter i cannot seem to find out what the problem is I don't here any squeeling noises so I don't think it's a vacuum leak but there's so many hoses it's hard to tell
Do you have a check engine light? If so, scan it and post the codes here.
Try disconnecting/reconnecting the battery and recalibrating the electronic throttle: https://mustangforums.com/forum/2005...-throttle.html
This is a common symptom of a car with a weak Vac.
A quick test for vacuum leaks is to spray starting fluid around suspected areas. The car will rev up for a second if you hit a leak. I would spray around the injector seals as well.
I cleaned the maf sensor cleaned the throttle body then I decided to change the throttle body and the problem went away but now when I put the car in neutral while the car is moving the rpms will drop to 500 and then the car will die there is no check engine light
johnnie_2207@yahoo.com
12-19-2015 03:10 AM
12-07-2015 06:55 AM
skinzy98
11-18-2015 10:23 AM
