2013 GT internal noise
Hi, everybody. I am a international student and I have a 2013 mustang GT, there are some problems bother me. I change the whole stock suspension to the Eibach pro kits (include dampers springs sway bar and anti roll bar) but these days when I drive my car the rear suspension has very loud squeeze. I went 281 Motorsport and my local ford dealer they did not fixed my problem. And second problem is my dash board I guess the AC vents and driver side rear panel has rattle when I drive my car in the bumpy way. I am a foreigner live in Riverside CA,and lots of bodyshop seemed does not like to help me to fix my problems.
What should I do? And does anybody can tell me where can I fix the problems? Thank
You!
You!
Your loud squeak is probably the sway bar bushings which are poly and need to be lubed to prevent binding and noise. As far as the noise in the dash, bite the bullet and take it to a Ford dealer. They would have a much better idea than some jack leg auto repair shop.
And I found the problems like my car from YouTue
Thank you! I will show my problems to dealership, and if I fixed it I will tell you! It is very kind of you!!!!
mohammadkhannj@gmail.com
02-21-2016 03:01 PM
