Advice on a Failed clutch last night
2007 Mustang:
A week ago I felt my clutch not engaging or changing gears, had to attempt multiple times to change gear.
Last night it failed completely, I was on the freeway switching to 4th gear and it just gave out. I rode the car out to the exit, the transmission fluid was smelling bad. I had it towed to home.
On Monday I am getting it towed to a shop.
I wanted your guy's advice on what questions to ask the mechanic and what to look out for so I don't get dinged with a ridiculous bill.
The guy towing the car told me I can change the blutch myself and that its easy (i doubt that). But I dont want to pay more than I need to if I can make sure the actual problem is addressed.
Thanks again, Great forum here!
Thanks for the help and advice!
Sounds like either the clutch master cylinder or the slave cylinder has bit the dust and there's no hydraulic pressure to disengage the clutch plate.
Obviously the tranny is still in gear when you're trying to crank the engine so shift it into neutral while the engine's still off before you crank it again.
