Dome Lights stay on- please help
need help- please read my issue because I HAVE look everywhere on this site and others and it seems no one had the SAME problem I'm having.
My dome lights stay on and will only turn off when the key is in and the car is in the run or started. Then when you turn the car off and remove the key the dome lights come on and can't be turned off either by pressing the buttons or opening and closing the door. Now the only way I can exit the car is to open the door and then removing the key, get out and shut the door that works.
I know others have had issues with them staying on and not turning off- mine will turn off only with the above steps.
fYI- when the car is in the run or start position you can push the button and the lights work like normal.
I have play with the switch by the headlights....nothing any advice?
