Door ajar and window not working
Hello fellow stang owners I recently bought a 2005 GT it had some minor problems I was just wondering if anyone has the same problems and knows the fix. First the little display screen on the dash cluster says "passenger door ajar" even when it's closed. Second the passenger window won't roll down but it dose go down a little opening and closing the door and my gas and coolant temp Gage's don't work. Any insight into these problems would be greatly appreciated thanks!
SJB in the passenger side kick panel. remove (1 10mm bolt in center) then clean all the corresponding plugs, both ends. if needed, take it apart and clean the board. then check your cowl drains for blockage and if needed, reseal the 10 cowl clips. gauges could be just the stepper motors that make them move. all the issues you have are very well searchable in google or on this or any other forum site. welcome and good luck
