Sponsored by:
Sponsored by:
GT500 shifter Noise/Rattle/Vibration?
Old 10-14-2017, 11:57 AM
SkyWitit23
SkyWitit23's Avatar
Default GT500 shifter Noise/Rattle/Vibration?
Hey Guys,
I知 a new owner of a 2011 Shelby GT500 SVT packedge 6 speed.
The car has 12k miles on it. In 1st 2nd 5th and 6th I hear this humming/very slight vibration noise and some rattleing when going between gears, I never noticed it because I always had the music on. Now I hear it because I知 looking for it haha
The weird part of this is in 5th or 6th if I move the shifter over to Right side maybe 1/8th of and inch it goes away, same with 1st 2nd but pull it towards the left ..it痴 doesnt do this sound in 3 or 4th gear because I知 guessing the shifter isn稚 to the left or right side. I知 wondering is something wrong here, 6th is louder then all the rest. I値l attach a video let me know what you guys think. It痴 very short because of the 5MB threshold but you can tell what I知 talking about.
SkyWitit23 is offline
Old 10-15-2017, 06:54 AM
SkyWitit23
SkyWitit23's Avatar
I guess no one has an idea? If this is a tranny issue or shifter? Can this shifter be adjusted?
Old 10-15-2017, 09:35 AM
1 Alibi 2
1 Alibi 2's Avatar
Does the car have an after market shifter in it ?
The Barton I had in my 11 transmitted more noise to the cabin than the stock shifter.
1 Alibi 2 is offline
Old 10-16-2017, 10:21 AM
SkyWitit23
SkyWitit23's Avatar
Not that I know of no. What is weird if it痴 moved slightly the noise goes away. So it seems like a physical thing but I知 not sure though. Does your do the same with moving the shifter slightly?
Old 10-16-2017, 02:04 PM
1 Alibi 2
1 Alibi 2's Avatar
Originally Posted by SkyWitit23
Not that I know of no. What is weird if it’s moved slightly the noise goes away. So it seems like a physical thing but I’m not sure though. Does your do the same with moving the shifter slightly?
I don't have any slop in my linkage, if that's what you're asking ?
And I removed the rubber isolation block when I replaced the shift handle.
Old 10-17-2017, 03:08 PM
SkyWitit23
SkyWitit23's Avatar
No I mean when in gear moving it slightly takes away the sound/vibration if thats indeed what it is. Check out my videos I posted. I show what I’m referring to.
Old 10-19-2017, 03:18 PM
SkyWitit23
SkyWitit23's Avatar
Anyone else?
Old 10-20-2017, 11:06 AM
svastano
svastano's Avatar
Sounds like a tranny issue to me, bad bearing possibly
svastano is offline
Old 10-20-2017, 10:08 PM
SkyWitit23
SkyWitit23's Avatar
What bearing?
Old 10-20-2017, 11:39 PM
SkyWitit23
SkyWitit23's Avatar
I took the center console up and I think I have a Barton shifter, is that good? Could that be the issue, I noticed the rubber grommet on the bottom of the shifter is cracked I wonder if that’s what’s causeing the shifter to go further over to make the noise.
