2005 Mustang Automatic Transmission not going into gear
Also, the valve bodies on these cars have a thermostatic valve. That means that fluid flow is reduced/cut off until the fluid reaches a certain temperature. Normally that's not a problem but, low on fluid and that valve being closed would cause a no-shift issue. The valve could also be stuck closed (if this happens when warm too).
Any leaks or anything under the car?
At 116K do you know if the tranny fluid has every been replaced in the car?
Derf is right on. Try letting the car idle for a while, maybe even as long as an hour. Then check the fluid level. If it's nice and red, add some if it's low.
So I just leave the car on for an hour and then check the fluids correct ? I just tried turning it on again and when I put it in reverse and step on the gas, the car would inch forward. But when put on Drive, the car wouldn’t move.
If the car didn't move at all regardless of whether the shifter was in D,1,2,3 or R, the cause would be a very low (or no) line pressure either due to a low tranny fluid level or a failed tranny oil pump. Since your car does move when the shifter is in R but not when it's in D, that suggests a different cause that can only be investigated and rectified by an auto tranny shop.
Before you do that, check the color of the transmission fluid. If it's pinkish, you could try replacing the fluid & filter (DON'T FLUSH) to see if that improves things. If it's brownish or black, the likelihood is that the clutch packs have burnt up and the tranny would need a complete rebuild.
So. We towed my car to an auto shop and they told us that the car need a whole new transmission totaling $4,177. I really do not want to pay this price for a new transmission. Should I just ask them to replace the transmission fluid and the filter? And then see if that works?
temtoy
06-11-2017 02:58 AM
Mnuckolls
01-31-2017 01:56 PM
BiohazardDeath
07-20-2016 02:01 PM
