need help with tire wear
i have michelin pilot super sport oem tire size. My rear tires are wearing more on outside then inside. To be specific the outer wear bar is the lowest, middle of tire wear bar has about 2mm less wear and the inner wear bar has about 3-4mm less wear.
Damn. You should take it to a tire/alignment shop and they can see what exactly would be causing that uneven wear. Do you do a lot of aggressive driving, or race the car on a track with turns? Does anything underneath the car look loose or out of place? Can you see from looking at the rear of the car if the wheels are at an angle?
With a solid rear axle, there is little cause for abnormal wear.
Center tire wear is over inflation. There isn't an alignment issue that causes
center only tire wear, only over inflation.
High speed cornering will also show edge wear.
There are no castor, camber, or toe adjustments on a solid rear axle suspension.
All abnormal tire wear is going to be from bad or misaligned parts, or improperly
inflated tires. While, there is a castor setting for rear axles, once it is in, it
should never need adjusted. This changes the angle of the pinion.
A bad thrust angle will have bad tire wear, like out of toe, and that's bad suspension
parts, those that hold the axle in place.
This also puts the wheels out of toe. One side will wear inner, the other outer.
Bad axle bearings can put the rear wheels out of toe, because the axle is moving,
thus putting the tires on a slight angle when in motion. The axle will have pendulum
movement with bad bearings.
i forget to add about 3k miles ago rotated my even wear front tires to the rear and now 3k miles later im already getting about 1.2 mm wear difference between inner and outer. Before i rotated the rear to the front i had about 5k miles and the difference were about 2mm inner and outer. Can this be characteristic of the tire? wheels/steering has no play as far as i know
not sure if its relevent but i do have a sub box and a 10"woofer in the passenger trunk corner but nothing on driver side. im still getting similar wear on both rear
Inner and outer tire wear would be an indication of bad camber, if on the front.
I can only guess now, the rear axle thrust angle is off, or it's not 100%
horizontal.
If front right tire has outer wear, and the rear left is inner, then the thrust angle
is to the right. Or, the axle is up higher on the left, tilting the right wheel out
to ride the outside edge, while the left rides the inside edge.
horizontal.
This wear pattern on both rear tires could have several causes. Hard cornering + slight underinflation or slightly positive rear camber is what first comes to mind. Hard cornering + wheels not quite wide enough for the cornering you're doing could be another. Or it could be a combination of all three.
Stick axles absolutely can have non-zero values for both camber and toe, and everything still works just fine as long as the axle splines aren't binding in the side gears.
Norm
