Brake light issue
Brake light issue
Ok so my running lights work(when I turn on my headlights they turn on,they are the same bulb as the brake lights) but whenever I press my brakes they don’t get brighter . When I use my blinker they do and my hazards so the bulbs are fine but I can’t figure out why they just stoped working .is there a fuse or a ground I can check (2007 gt)I
Check fuse #15 in the SJB (smart junction box). That's in the passenger side kick panel. Also check fuse #63 in the BEC (bussed electrical center). That's in the engine compartment passenger side. Also check your stop lamp switch behind the brake pedal. Good luck!
Wiring diagram:
http://iihs.net/fsm/?d=40&f=Turn%20S...rd%20Lamps.pdf
BEC:
http://iihs.net/fsm/?d=40&f=Fuse%20a...nformation.pdf
Stop lamp switch:
http://iihs.net/fsm/?d=391&f=Stoplamp%20Switch.pdf
Wiring diagram:
BEC:
Stop lamp switch:
