2005 Mustang GT - Multiple Codes
So driving home a few days ago, I get the check engine light with a code P0443. Mechanic is leaning heavily towards ECM, but based on some reading I'm ruling it out. The following is the list of events that occured
P0155 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0161 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0443 - Evaporative Emission Control System Purge Control Valve Circuit
Check Engine Light Comes on at this point
P0135 - 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 - 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Any Ideas where to look, or does it appear to be a bad ECM?
This is a Mustang GT 2005
Then I read somewhere the heater resistance codes are used to indicate certain cat malfunctions. My rig has 165k+, original cats, so definitely possible. That's where I'll go next. The heaters work fine, electrically everything checks. BTW, I replaced the ECM, no change!
If you have lots of miles, or even if not, look to the cats! imp
Update, Mechanic didn't do anything and code has seemed to go away. Previously my mechanic replaced the Control Valve Solenoid, but refunded me since it didn't fix the issue. He checked for a short, didn't find anything. Checked fuse 47, no issues there. Any ideas?
I would ignore P0443 for now and focus on the O2 sensors. The harnesses for the rear O2 sensors are down UNDER and behind the bell housing of the transmission, most likely under a black plastic cover.. Check those connectors and wires first for shorts, burnt or exposed wires. Also check your Front O2 sensors for the same.
Have you had any type of work done on the car before it started having problems or did you drive through any deep water?
No work done on the car. No deep water. Now I took it to the Ford Dealer they didn't find anything wrong as well, they just reset the ECU and everything has been fine since. But I did notice they did do something in the front fuse box, the fuse in 47 was newer. (I put a dot with a sharpie on it)
Update the light came on again. My mechanic after replacing everything still the code keeps coming back, he's thinking it's a short somewhere in the system. Have an appointment Wed with Ford to look at this.
