Rear grinding noise 06 GT
A Panhard bar doesn't just get bent because you bump something. You gotta hit it hard. I'd be looking at upper shock tower damage and lower control arm frame mounting damage with the way that thing is pretzled in there. Also if you look at the sway bar on that side (right side) the bushing does not appear to be sitting in the original spot. More evidence on a something being severely misaligned.
When you got it aligned, did you get a print out of the before and current results? I'd be interested in seeing the Thrust Angle. Thrust angle tells you how centered the rear axle is to the front (imaginary) axle. If you've every heard the term, dog tracking? It's when the rear hangs out excessively to the left or right of the car/truck and looks like the rear is following it's own imaginary center line that is different from the front.
Anyways, it looks like someone lost control and the rear hit a curb/sidewalk pretty hard. Bent the crap outta the axle and they juts replaced the axle or got things bent back to kinda drive straight and got rid of it. What's the carfax on the car say? I'm gonna guess either salvage or it was not reported.
I looked, and my untrained but observant eyes didn't see anything else wrong w regards to the UCAs and LCAs. As for the bushings on the sway bar, yup - the mechanic's assistant pointed it out, that the bushing wear on the bar is about 3/4" off. I'm hoping it's not too bad, and a new Panhard will straighten it out. Notice, too, the Panhard bar is resting on the left crossmember underneath it, and it's limiting the axle's left side from going down as far as the right.
I did get that. I'll need to get it back out to see...
Yup. If this car is doing it, it's not much.
No, axle on L side was slightly bent and brake rotor chirping on the bracket. Put in the new axle and rotor, and all seems well aside from knowing the Panhard bar is bent and pulling the whole axle a little to the R side of the chassis - about 3/4" or so. Carfax was clean, so I'm sure they did this and just didn't report it.
Knowing these details and pointing them out takes a keen eye, bl817!
Do you suppose these braces, if added to a hard top, would be an added benefit for structural rigidity?
Found another site, there was some cool info there, as well.
https://www.allfordmustangs.com/foru...-sway-bar.html
This one guy's car and panhard bar were a lot like mine. He replaced it and was G2G. I'll be replacing mine soon...
Daleford
07-29-2016 09:34 AM
