Vibration at 1100 rpm
This is my first post here so bear with me. Got my Mustang about ten months ago. Ran and drove perfectly when i bought it. After about 4months it developed this problem. Discovered that the diff was low on oil. Filled it. problem went away (mostly). Now it's back. In any gear, at any speed (especially going slower) there is a heavy vibration at exactly 1100 rpms. I can feel it in the seat (my butt), in the floorboard (the gas pedal), and in the steering wheel. if i accelerate faster it moves through the rpms faster and the vibration is not nearly as noticeable.
Do you get the same vibration at 1100rpm in neutral? If so, the rubber sandwich in the harmonic balancer may have perished causing the outer part of the balancer to separate.
I do not. It revs fine to 2000k and back down to idle. Only happens in gear.
Are there any other noises or whines? if not, Given by how you describe the vibration I would hazard a guess that you have a bad motor or transmission mount. I’m going to suggest the trans mount as my top suspect because you feel it in the seat and only under load. You should be able to support the trans with a jack and some wood so as not to damage the trans, then remove the trans mount and inspect it. What year and how many miles are on the car? |
Originally Posted by infiniphonic
(Post 8648961)
Originally Posted by Derf00
(Post 8648989)
From the front is what i am thinking as well. Have you ever heard of wheel hubs going bad and causing this kind of thing? They are becoming suspect and my plans for today include a complete and thorough inspection of them. It also could be the clutch/flywheel/throwout bearing/pilot bearing/input shaft bearing. I'm pretty sure all that jazz is original/never replaced.
Update
I put the rear on jackstands and ran it through idle to 1500k rpms. the vibration is still there but very faint. Almost like a hint of what i experience when i'm driving down the road. Also, the rear wheels remain slightly driven when the car is in neutral. That last part was a surprise to me as i thought being out of gear completely de-coupled the engine from the transmission.
(Post 8649009)
Worn wheel hub bearings can cause vibrations but they'd be road-speed related and worse when making turns. They aren't related to engine rpm. |
(Post 8649014)
You're right about the latter so it looks like the clutch isn't releasing completely. If you still have the original clutch from when it was new, it's probably shot and that would also account for the clunky shifts.
