2007 Mustang Premium GT Brake Lights
Old 06-15-2019, 10:33 AM
Jon Baitson
Default 2007 Mustang Premium GT Brake Lights
My 2007 brake lights are being a problem.
On the left side 2 out of the 3 lights don't work. I have replaced the bulbs, still don't work. I've swapped over bulb within the 3 and its only light #1 that works, regardless of which bulb i use.
1 2 3
1 3 2
2 3 1
Numbers are the bulb, red - not working, green working.
Could it be the fuse(s)? if so where are they? which one do I look for?
Could it be the turn signal? if so, where do I start?
Please help
Jon Baitson is offline
Old 06-15-2019, 11:12 AM
dusman59
dusman59's Avatar
I have seen several 05 thru 09 Mustangs with at least one or more tail lights out. Check the sockets for defects or burn damage. You also might get a test light that can trace the wire by piercing the insulation to find where the voltage drops out.
dusman59 is offline
Old 06-17-2019, 05:33 PM
bl817
bl817's Avatar
check for voltages at the individual sockets to see if they are getting power. if not, could be corrosion on the connector at the SJB (smart junction box) its located on pass side kickpanel. the tail lights run thru there, as do most other body controls. if it gets wet (known issue) it caused all kinds of electrical issues. you can get to most the connectors with it bolted to the car, unplug and check for corrosion. you can also search "cleaning SJB"... etc. good luck
bl817 is offline
Forcefed93gt
03-01-2012 05:27 AM
Dom M
10-04-2008 10:42 PM
phunnyguy
12
08-18-2006 10:09 PM
Quick Reply: 2007 Mustang Premium GT Brake Lights
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
