TSB For Seat Trim??
TSB For Seat Trim??
Anybody have any details on this:
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
I have this problem with my S281 on the drivers side. The front cover is loose under my legs, and I can't seem to figure out it attaches up under there [&:] Is this something that has to be replaced or is there a simple DIY fix to it??
05-19-10
RE: TSB For Seat Trim??
you can do it yourself. it involves bending the metal bracket that holds the trim slightly, and inserting a dime to check for correct clearance. I've seen the TSB somewhere...
Yup, a dime, as in $0.10. Now that is some fine engineering! At least Ford doesn't require a special $1000 tool to do it!
Wow - talk about a HIGH TECH TSB Needle nose pliers & a DIME - I think they left out the duct tape [8D]
Thanks for the link - I've just been double-bending my flap under to keep it in place.
