Clear Front Bumper Lenses
#31
RE: Clear Front Bumper Lenses
Great idea on the amber/clear LEDs. I bought some for the tail lights (red/clear LED) and they suck. The light only projects rearward and the unique reflector doesn't emulate the faux LED dots as it does with a standard bulb (i'm going to try 3157st's, Silver Stars). Don't waste your time on the rear tail lights unless they project light rearward and to the sides towards the reflector.
The amber marker lights on the front will probably look much better given the smooth chrome reflector... correct me on either account, if I'm wrong.
#32
Just got my Clear lights, i was suprised to see how big they were, i guess alot of it is hidden behind bumper, hope to install this weekend, but the weather up here in the NE still sucks.
#33
ORIGINAL: Hiboost
1. Turn wheels toward the side you are replacing.
2. Remove three metal screws and two plastic retainers in fender liner.
3. Pull fenderliner away from front.
4. Squeeze two clips with hands while pushing slightly on the lens.
5. Pull the outside end out and down to remove.
6. Notes: Passenger side has windshield washer bottle to work around. The key to putting them in is the angle, so pull the outside as far back as possible to allow the inner tab to slide into the retainer.
#34
I think it will look great on my car. Was planning to get them before but for some reason I just didn't think about it anymore. Would have been great to put them on when my bumper was off, but too late for that now. What does a set of clear corners run if you don't mind?
#38
ORIGINAL: torch red
is there a place besides E-bay to get these?
and here's a good installation tutorial that was linked in another thread: http://forums.bradbarnett.net/showth...=brake+install
i installed my clear turn signals about a week ago and it was pretty straightforward. all i needed was a short phillips head screwdriver and a pair of pliers to squeeze the 2 clips to remove the stock lenses
#39
You beat me to it !!!!!!! The link below is great and the lenses and the bulbs are awesome!
ORIGINAL: JibStyle
yes: http://www.stangmods.com/Mustang-Tur...ge-p/00877.htm
ORIGINAL: torch red
jwog666
12-27-2021 08:09 PM
