Smoked rear marker lights for 2010
I'd like to replace the front and rear side marker lights for smoked ones. I though of doing it myself with Niteshades but really don't want the hassle.
I found these on eBay for the front. I cannot seem to find ones for the rear. These should be cheap as the lens covers just pop off and the whole housing doesn't need to be replaced.
Anyone know if/where these are available? Thanks.
I'm a little leary of tint. If you get it, let me know how it goes. I might consider this.
Going to a body shop to have them painted will probably be too expensive. I'd prefer new smoked lenses/housings as I like the idea of being able to revert back to stock if need be.
Thanks for the suggestions.
Here is the page that shows the ones I got. I got the Tail Light (the first ones listed), 3rd light and Rear side markers on mine.
http://www.stangmods.com/Mustang-Tai...Tint-s/280.htm
Install took all of maybe 5-10 minutes. Just make sure that you clean the lenses real well with some iso alcohol and put the tint on when it is not windy out. Also it helps if it is warm/hot out as that will minimize the bubbles at first. Also don't freak out if you do have some bubbles as they will go away after a few days (as long as it is hot out & in the sun).
I had the ones on my 05 for almost 4 yrs with no problems whatsoever.
If you do order them, tell Matt (the owner) that Bill sent you, he will take care of you.
