Cleaning the black plastic trim
I think it is for exterior only. It has a pretty potent smell so I wouldn't want to use on the inside at least.
I've also had different experience then the other poster as I've not had the wax or grit show back up. We might be using differnt waxes or my blemishes werent as bad. Don't know but it's done good for me.
The other post about a strong cleaning solvent real good as well.
Long story short is a lot of good advise for you on this thread :-)
back to black does not remove the wax..it basically hides it and you cant tell its there. Even if you scrub with it. it will last a while but after so many washes it will come right back cause it will wear off. Mr Clean magic eraser works, I have heard also just get the large pencil erasers from the store and they work as well.
Pink pencil eraser will take care of it no problem.
For dressing black trim, I use Meguiar's Hyperdressing exclusively. It's awesome. You can use it slightly diluted for high gloss, or dilute 4:1 with water for a more matte finish.
TfcCDR
09-14-2015 12:08 PM
