Water spots
Water spots
I just detailed my car today and noticed some water spots etched into the paint. They are very minor and only noticeable when looking at certain angles. Can anyone recommend a good cleaner to remove them. Thanks.
Have you tried applying a wax? I have never had water spots on my car except while washing my car in the sun but they are so minor that when I dryed the car with a rag they disappeared. Clay barring the car will also remove them.
a coat of wax will do nothing but just put some protection on the paint..it will serve no purpose to remove water spots. unless it has alot of fillers to try and mask some of them..but they will just re appear after a few weeks of washes. first thing to do is try and clay bar it..if they are still just sitting on the paint....they they are actually etched into the paint then you will have to get a DA to buff them out or have someone do it for you. You can also try a mix of 50/50 vinegar and water to try and remove them.
But yep, if they're literally etched in, then depending on how bad they are, you could polish them out by hand if you have the elbow grease, or use a machine polisher to make it happen faster.
