Water spots
Old 07-09-2011, 06:27 PM
BlueBellThunder
BlueBellThunder's Avatar
Default Water spots
I just detailed my car today and noticed some water spots etched into the paint. They are very minor and only noticeable when looking at certain angles. Can anyone recommend a good cleaner to remove them. Thanks.
BlueBellThunder is offline
Old 07-09-2011, 09:39 PM
grabber blue gt
grabber blue gt's Avatar
Have you tried applying a wax? I have never had water spots on my car except while washing my car in the sun but they are so minor that when I dryed the car with a rag they disappeared. Clay barring the car will also remove them.
grabber blue gt is offline
Old 07-09-2011, 09:44 PM
05SatinSilverGT
05SatinSilverGT's Avatar
^ Agreed, a coat of wax should do it. If they're really stubborn a clay bar & a good polish should take care of it.
05SatinSilverGT is offline
Old 07-09-2011, 10:01 PM
pdonket
pdonket's Avatar
Yep, clay bar the car first, then apply a coat of wax after drying the car and it should solve that, and make sure you don't run into it again
Exterior maintenance is a lot of work but is worth it.
pdonket is offline
Old 07-09-2011, 10:31 PM
05xrunner
05xrunner's Avatar
a coat of wax will do nothing but just put some protection on the paint..it will serve no purpose to remove water spots. unless it has alot of fillers to try and mask some of them..but they will just re appear after a few weeks of washes. first thing to do is try and clay bar it..if they are still just sitting on the paint....they they are actually etched into the paint then you will have to get a DA to buff them out or have someone do it for you. You can also try a mix of 50/50 vinegar and water to try and remove them.
05xrunner is offline
Old 07-09-2011, 10:35 PM
2011Kona3.7L
2011Kona3.7L's Avatar
this is what i use - http://www.autogeek.net/motcalgolind.html
2011Kona3.7L is offline
Old 07-09-2011, 11:28 PM
05xrunner
05xrunner's Avatar
that wont do anything for water spots..that is just a cleaner between washes when the car is only dusty. it will not remove etched waterspots.
Old 07-09-2011, 11:56 PM
rangerryda
rangerryda's Avatar
I second the clay bar. After that, MAINTAIN a nice waxed surface or else you're just asking for more surface etching.
rangerryda is offline
Old 07-10-2011, 12:11 AM
grabber blue gt
Maybe mine werent etched in because I sometimes get waterspots since I have no shade to wash my car, and if I follow up with a quick spray wax they disappear. But like I said I have never had them REALLY bad where they were etched in the paint.
Old 07-10-2011, 04:55 PM
pdonket
pdonket's Avatar
It all depends on how bad the water spots are. Sometimes they aren't literally etched but they'll leave a ring from particulate that dried onto the surface while the water evaporated, and a quick detailer or spray way can remove that.
But yep, if they're literally etched in, then depending on how bad they are, you could polish them out by hand if you have the elbow grease, or use a machine polisher to make it happen faster.
pdonket is offline
Quick Reply: Water spots
