My Retrofit HIDs
My Retrofit HIDs
The Story: I had HIDs in OEM housings, which were pretty terrible. Light went everywhere. Then, I bought Raxiom Projectors from AM. This was better, but the output wasn't as good as I expected (even with 4300K HID).
I decided to go with a retrofit a few weeks ago.
A member here, StockD15b had/has an "ad" in the FS section for HID retrofits (Edit: Now on Facebook!)I PMed him (a lot) about what I wanted, and shipped my OEM lights out to him.
The Build:
Morimoto Mini H1 w/Mini Gattling Shrouds
5000K bulbs
Black painted housings & Shrouds
Removed amber turn signal reflector
Iridescent Sylvania Bulbs
I'm very pleased with how they turned out. The output is night/day, even when compared to Raxiom Projectors. They were very professionally installed, and Kris provided updates through out the process. PM StockD15b or look up his thread in the FS section for his prices.
One Projector:
(Mind the glare...my camera sucks)
The Build:
5000K bulbs
One Projector:
I see your retrofitter copied my retrofit from sickhids. I was wondering why he was PMing me so much recently. Cool look isn't it? Do your turn signals switch from crystal running lights to amber? They're called switchbacks,
Also, they're not switchbacks. They're Silvania halogens with an iridescent coating on them.
They cost me right around $400. Price varies depending on the options you choose. Projector type, shroud design, bulbs or no bulbs, wiring harness, etc...
I had my original OEM lights lying around because I had bought the Raxioms months back, but if you need a brand new set of lights for the retrofit, he can hook you up with those as well.
It was well worth it. Nothing compares to HIDs in projectors designed for them. Thanks for the comments!
Brian,they look great glad you like them. how would you describe the difference between the factory lights vs the Raxioms vs HID projectors?
Freyes, Im sorry if this build resembles yours. Your and I pm's were never in regards to the "look" rather a fitment question since i was under the impression you had done yours your self.
This was more of a budget build.I used the shrouds that came supplied with the projectors, i could have gone with a different shroud, but that would have bumped up tottal cost.And again,this was more of a budget build.Brian and I consulted back in fourth numerous times in regards to what the look we wanted to achieve. it boils down to this..
Stock
with amber diffuser
without
I think we'd all agree the latter is the better overall look.
Oh, and now we can enjoy being in the elite club of HID projector retrofits!!
Stock
with amber diffuser
without
For comparison, retrofit is by far the best option (aside from factory HID). HIDs installed in factory reflector housings cause glare, and throw light upwards. It's not very usable. You get the "look" of HID, but none of the cut-off and color flicker you get with projectors.
Raxioms are a good step up from HIDs in halogen reflectors. I had the smoked lens version, which definitely reduced light output. IMO, HIDs are a necessity for smoked Raxioms. The light the included halogen bulbs provide is on par (if not slightly worse) than standard reflectors + halogens. Even with HIDs, the Raxiom projectors don't put out enough light, especially on foggy/rainy nights. You get a decent beam cut-off, but it's not very straight, along with minimal color band.
Retrofit is the best choice. There is a sharp beam cut-off line, with a great color band and wide beam pattern. The 5000k bulbs I'm running provide more light than Raxioms with 4300k bulbs. Remember, the higher the kelvin, the lower the lumens. So even with a lower lumen count, the retrofits put out more usable light than Raxioms with a higher lumen count bulb. This is due to the better quality Morimoto projectors and clear outer lens.
If you're going to spend the $ on projectors, skip the Raxioms and do a Retrofit. The extra cost means a world of difference in performance.
On my previous post, when I used the word "copied", I was talking about removing the amber turn signal reflector, and whether the OP's retrofitter had used switchbacks, as this is what Stock15b and I discussed on numerous PMs. I meant no disrespect, as the OP seems to have reacted as though I had. I was wondering whether the turn signals worked the way mine do, crystal when used as running lights, and amber when used as turn signals, but from the photos, only amber bulbs were used.
Stock15b, I realized this was a budget build due to the equipment used.
FYI, I normally do all my own work, but contracted out my retrofit since I was getting my elbow replaced. Still looks great. Welcome to the HID club.
