Looks good,did you just spray it?I've had mine off several times,always afraid the strut mount bolts are going to snap when I retighten,they feel so cheap.
Hey,where are your engine covers,are you doing those also?
thanks, no the dealer did it while having some warranty work done for some dirt in paint behind wheel well from factory. Spec is 26 ft-lb torque for the nuts... the MCA here in Canada didn't come with an engine cover, just found out that it is a performance package item and will investigate, likely cost an arm / leg.
