Sportline or Pro Kit ??? Help
Old 07-16-2012, 07:42 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by conway2004
Decided to go with the sport lines . Will be ordering in next day or so !
Make sure you pick up an adjustable panhard bar because you'll NEED one with Sportlines!
http://www.uprproducts.com/mustang-p...rd-bar-05.html
UPRSharad is offline
Old 07-16-2012, 09:55 PM
MadStang40
MadStang40's Avatar
Yep, I'm really wanting to see your before and afters here. I've been wondering if I should throw on another pro kit or some sportlines for the 2012/2013 I eventually pick up
MadStang40 is offline
Old 07-18-2012, 12:18 PM
TommyB681
TommyB681's Avatar
i have sportlines on my other car. if its the same for mustangs the sportlines give you more of a drop.
TommyB681 is offline
Old 07-18-2012, 05:52 PM
wanakanabe
wanakanabe's Avatar
I was on the fence too,went with Pro,couldn't be happier.This is on 20'sDidn't need a ph bar or anything else.Rides great and only had a slight toe adjustment made.How low can ya go!
wanakanabe is offline
Old 07-22-2012, 09:03 AM
starbai
starbai's Avatar
sportlines for sure...
i understand the need for pro kits for people in areas with crappy roads... and wanting to retain a 'comfortable' ride as best as possible... but to me there's barely a noticeable difference... in looks anyways.
I'm on sportlines... and wish i could be slightly lower up front still.
starbai is offline
Old 12-27-2013, 11:34 AM
starbai
starbai's Avatar
absolutely do need one, mine was a good bit off... I went with the Steeda adjustable though.
starbai is offline
Old 12-27-2013, 01:44 PM
2012StangMan
2012StangMan's Avatar
The sportlines will give you the look you want. An adj. panhard bar is a must. With the aggressive drop like the sportlines I would highly recommend either camber bolts or cc plates to align the front tires, and an adj. UCA. The adj. UCA will help you get your pinion angle back into spec. It will drive okay without one, but it will prematurely wear out your diff seal. You will know if you need one if you have any vibrations in the drivetrain.
2012StangMan is offline
Old 12-27-2013, 02:08 PM
starbai
starbai's Avatar
This is a very good point... my front end definitely had some negative camber (not intended) and it took a toll on the tires after about 20k mi.
starbai is offline
Old 12-27-2013, 02:38 PM
2012StangMan
When I lowered mine with the H&R super sports, it threw mine to about a -1.8 That's not terrible but it needed correction. You can go with camber bolts but I would highly recommend the extra $ and go with caster/camber plates. Those camber bolts will work, but are known for failing. Even on just regular street use. The cc plates are safer and offer a wider range of adjustment than the camber bolts.
Old 12-28-2013, 11:45 PM
Greed1
Greed1's Avatar
Sock height on 19's
With sportline drop. Still on 19's, just different wheels.
Greed1 is offline
jwog666
12-27-2021 08:09 PM
mapitts
05-11-2016 10:14 AM
jerrytubes
10-23-2015 12:11 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Sportline or Pro Kit ??? Help
