FYI - 2013 tail lights are NOT Plug in and Play
Old 03-24-2013, 01:55 PM
  #21
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Well I found the wires I needed from a '13 GT and lookie, lookie what I did.
Matthew
Matt's 95 Stang is offline
Old 06-27-2014, 05:55 PM
  #22
UltArc
UltArc's Avatar
Mattt-
I tried to send you a PM, but it didn't work. New to this forum, but been fine tuning my Mustang for a couple of years. I wanted to see what you did with the hook up, but your image is no longer active. Internet cookies for posting it again?
My current situation:
Bought a 2013 tail light to see if I would like it.
Didn't come with the wire, so it is just the lamp.
Decided I liked it, but haven't seen it lit up.
Ordered the other light, which comes with the pigtail.
I bought a new wiring harness to set it up, thinking this had the big tail- it did not.
So now I have a 2013 tail light harness, which is valueless to me, a 2013 tail light that won't hook up, and a new 2013 tail light on it's way, that won't hook up when it gets here.
So I am very frustrated, and not happy that so many sites said it was plug and play, when it is not. Specifically, like here: http://www.stangtv.com/tech-stories/...to-13-14-spec/
Anyway, until I write a starting here thread, a lot of my work is on Ecomodder under UltArc, and my quarter baked website, www.aerostang.com.
Look forward to hearing back, sir.
UltArc is offline
Old 06-28-2014, 11:11 PM
  #23
UltArc
UltArc's Avatar
Has anyone had any success with this?
Matt, would you mind showing me your setup? I've done a LOT of searching, and this was the first (and only) thread I found about a work around. I saw these shots:
But didn't see a setup for getting it together. I would start experimenting, but haven't gotten my full tail light yet. Hopefully I can get a head start with your help!
UltArc is offline
Old 07-04-2014, 08:27 AM
  #24
Matt's 95 Stang
Resident Ginger
Sorry for the delay, I saw your PM but couldnt respond due to your post count. There are two different versions of the taillights; the USA version and the EU version. The first set of taillights I bought were the EU version which is why my pigtails were not plug in and play. After I realized that I had the wrong ones I ended up getting a set of USA lights and they worked just fine. If you need a set of light pigtails I have an extra set I bought while trying to figure out what the problem was. If you need just the pigtails let me know and we can work something out.
Matthew
Old 07-30-2014, 09:05 AM
  #25
Andrew Christian
Andrew Christian's Avatar
Matthew
So now you're saying there is a version that IS plug and play? You should link to them and modify your original post to avoid confusion.
Andrew Christian is offline
Old 07-30-2014, 01:56 PM
  #26
Matt's 95 Stang
Resident Ginger
Well I did come on here and correct myself in another thread (https://mustangforums.com/forum/2010...-and-play.html), and yes there is a version that is plug in and play. The USA version that come in red amber lenses are plug in and play. The EU version that have gray/clear lenses are NOT plug in and play.
Matthew
Old 05-15-2015, 08:56 AM
  #27
Drew521
Drew521's Avatar
Where the bleep did you get a pair for $450?
Drew521 is offline
Nick Oliver
10-17-2018 04:22 AM
zachary1988
09-04-2015 03:04 PM
Emblazoned
09-03-2015 10:45 PM
iamgobono
09-03-2015 12:37 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: FYI - 2013 tail lights are NOT Plug in and Play
