V6 Fog light install help
Old 04-02-2013, 10:01 AM
Paul_VS
Paul_VS's Avatar
Default V6 Fog light install help
I've got a set of fog lights, bezels & wiring harness for my 2012 V6. The install seems quite simple, but as I understand it, the splash guard needs to be removed underneath to install the lights... with 9 screws holding it in.
Can anyone who has done this tell me where exactly the 9 screws are located?
Thanks!
Paul_VS is offline
Old 04-02-2013, 04:34 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
They hold the front bumper to the frame under the front of the car. Just look under the front of the car and you will see them. Cant miss 'em
Matthew
Matt's 95 Stang is offline
Old 04-02-2013, 09:38 PM
Paul_VS
Paul_VS's Avatar
Thanks! I decided to take an easier route for me than getting under the car.... I removed the wheel well liners and got to 'em from there. Worked great. Now I just have to find out where to connect the ignition wire of the wiring harness should connect. I tried them out just connecting it to the battery terminal in the fuse box and they look great. Less than $100 for new factory fog lights! (Minus the factory switch)
Paul_VS is offline
Old 04-03-2013, 12:37 PM
Paul_VS
Paul_VS's Avatar
Paul_VS is offline
Old 04-03-2013, 10:02 PM
Matt's 95 Stang
Resident Ginger
Look at Starkey products. They make great stuff. I got their foglights wiring kit and the fit and finish was 10/10. They probably have a wiring kit that will fit your need.
Looks good to. I always thought foglights should be standard on the Mustang.
Matthew
Old 03-22-2014, 07:05 PM
oldgiff
oldgiff's Avatar
Do I screw the fog lights on from the back or the front? Thats all I really need to know me and my bud already did the wiring and we try to put it in from the front but the foglight sticks out too much for the cover to pop on so I'd like a little advice - Franklin
oldgiff is offline
djbigskrilla
09-20-2022 01:04 AM
Diode Dynamics
28
05-26-2022 12:02 PM
MustangHead91
08-23-2015 09:37 PM
inyadreems
08-21-2015 09:10 AM
dseg
08-08-2015 09:00 PM
Quick Reply: V6 Fog light install help
