WHAT is physically preventing the fit? The strut towers and bolt patterns are the same with any motor
in it, so what is the actual problem with fitment? Won't clear the hood? Motor?
After looking at the '14 V6 and their selection of braces, I wondered the same thing. I looked into it awhile back, supposedly the s550's engine is a little bit higher up in the bay. The braces will clear but barely, the only problem is when the engine torques under load itll push up, potentially cracking the manifold. One person attempted using spacers on the bolts but it pushed up on the hood too much, pushing it up a bit. The only successfully installations I've read of was dropping everything with new motor mounts. Sucks, because I was interested as well.
You can install one but you need to use thick washers as spacers. Several have done this. The reason the strut braces done work as designed is because of our god awful intake manifold that sits too high.
