Battery Maintainer Question
I have an automatic low amperage battery maintainer with a cigarette style plug in adapter that I use to keep another vehicle's battery fully charged during prolonged periods of inactivity. It simply plugs into an accessory port that is always hot. Will it work the same way on my newly acquired 2016 convertible?
It's most likely the hidden port in the center console that is Hot at all times. The one that is on the dash or in the center dash stack is usually the switched one.
If you have a 12v USB charger, plug it in and see which one charges your phone without a key/FOB present.
Tested both the front console and center armrest aux power ports this morning. Neither are continuously hot, so looks like the battery cover will have to be removed to allow my maintainer's set of alligator clips to connect to the battery post. Nuts! Would have been so much easier to just use the optional lighter style plug to insert into one of those aux ports.
that sucks! Must've been too many complaints from people leaving stuff plugged into the hot port to drain the battery so Ford decided to make them both controlled by FOB The few dipshizzs affecting the greater who are not....
