Here's Some Smack Talk from Jalopnik
Found this tidbit below, here http://jalopnik.com/5408309/2011-for...5-hp-v6-30-mpg
"What we are interested in is the rather off-hand comment from one of the engineers regarding the track pack. Optional on the V6, the track pack turns things up a notch and makes it a track-day special. Said unnamed engineer mentioned there's a distinct possibility the track-pack equipped V6 will not only stick with the V8 track-pack 'Stang, it might even outrun it. Well, we would certainly be happy to test that theory out."
Yes, “your results may vary” as they say. With enough straightaway, no go, but the lighter weight and better (nearly 50/50) front-to-rear balance of the V6 could give it an edge on a more tight road course. You’d be busier with the stick too, but interesting that a Ford Engineer made the statement, not Jalopnik.
I have no problem with that statement. The differentiating factor would be the course of play. A tight, short track with little room for the V8 to stretch it's legs would certainly be the prime hunting ground for the V6. It has a great weight advantage in the front half of the car that will make for a more manageable pony. Turn off the speed limiter and the mid sized tracks may have some interesting sparring to see. Get on the long track with enough straight-away to allow the 5.0 to break out front and it might turn into a tug of war as the V8 reclaimed everything the V6 stole in the last couple of corners. Sounds fun!
breaking
10-02-2015 01:27 PM
09-27-2015 03:16 PM
