3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Halo Headlights troubleshoot
Old 11-26-2011, 07:03 PM
jphn
jphn's Avatar
Default Halo Headlights troubleshoot
I've installed halos (http://www.americanmuscle.com/smoked...ghts-0509.html) but the passenger's side halo keeps going out from time to time. At first, I had the wires connected by using insulated disconnect connectors. I then tried using just heat shrink tubing which didn't work either. And now, I've soldered the wires together and the halo is still going out. The driver's side halo has never gone out though.
Could it be that the headlight is faulty or is it still the wiring job? I tried calling AmericanMuscle but the employee didn't seem to be much help and didn't really know the answer either.
jphn is offline
Old 11-26-2011, 07:12 PM
JayyVee
JayyVee's Avatar
You might want to try in the american muscle forum area directly, or by reaching out to Chris (AMChrisYoung I blv is his username!), he's very helpful and may be able to give you some ideas of things to check.
Outside of the one going in/out, hows the quality/light output/cool factor on those?
JayyVee is offline
Old 11-26-2011, 07:17 PM
jphn
jphn's Avatar
Googled a bit. This link, right? http://www.allfordmustangs.com/forums/americanmuscle/
They look really nice. It's just that if one of them is out, it looks completely dumb.
jphn is offline
Old 11-28-2011, 10:57 AM
JayyVee
JayyVee's Avatar
Try the AM forum here on MF as well.
https://mustangforums.com/forum/americanmuscle-com-73/
JayyVee is offline
Old 12-07-2011, 12:06 AM
anglejel27
anglejel27's Avatar
The purpose of heat shrink tubing is to also guard wires and small parts from damage. The combining and fixing wires also happens when needed. In a process like Electrical Engineering heat shrink tubing is used for connections, terminals, wires, and joints that
need to be padded.
heat shrink tubing
anglejel27 is offline
Old 12-07-2011, 12:08 AM
anglejel27
anglejel27's Avatar
Heat shrink tubing comes in multiple types and this is performed via the process of using a color code. This is done so when we're dealing with connectors and wires the use of a color code makes things more identifiable.
heat shrink tubing
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
rksnow1
09-14-2015 08:46 PM
Quick Reply: Halo Headlights troubleshoot
