2013 transmission issue
So my new 2013 w/ auto trans will not break the rears loose. If brake is applied and gas pedapedal mashed the engine will hold at 2K rpm (yes the advance trac is turned off) I took it to the Ford dealer and test drove it with a tech, he said that "that's how they are made now". Is anyone else out there having an issue like this? I only have 3K miles on it and am going back to the dealership to discuss swapping for a manual. I am wondering if a tuner could possibly fix the problem. Any help/advice would be appreciated.
I found that same thing on my 2013 when I took it to the drag strip (only 430 miles on it at that time). Almost like a 2 step built in, would not go above 2,000 rpm; I assumed it is part of the torque management system. And like you it didn't matter if the TCS was off or the entire advance trac system.
But I also found using the track app that the 0 - 60 was a little quicker just go off idle rather than taching up to 2,000; a little bit of a surprise.
I too have this problem...
I have tried EVERYTHING to get a some type of burnout going. And I ain't got nothing working. Chirped the tires ONCE. (And that was going UP a hill)
My 4.0 (RIP) had the same problem until I tuned it. Once I tuned it, I swear to god, things changed, FAST. However, I do want to look into getting 3.55's installed. I even went to evolution performance today, (I live around the corner) and they quoted me at $690 for parts and install. And then $250 to set up a tune on my unlocked tuner. I just came to the point that I was like, "Thank You" walked out, and decided I'm gonna hope for the Intake and Tune from American Muscle to fix the problem.
Doug is making some headway on this - I've been talking with him the last couple of days and I tried a test an hour or so after the rain stopped tonight and was able to break the tires free pretty easily. Still need to do some more on road testing.
Loaded a 93 tune that Doug did some work on for shifting, turned the TCS off (just one push of the button, I didn't turn off the Advance Track by stepping on the brake and holding the button for 5 seconds). I was really only doing it to test if the rpm's were limited to 2,000 still or if it would me to get a little more on the convertor and accelerate from a stop better - and suddenly "squeal" and a little smoke. The road was wet, but before that tune I couldn't get above 2,000 rpm and even with that the rear stayed put with no movement of the tires.
I don't know if Doug has determined that he got this issue figured out and is ready to declare 'success' - I'm sure he will be studying the information tomorrow and hope he doesn't mind my posting that I managed a burn out tonight doing some testing.
