Torque for 2011 v6 3.7 water pump replacement
Replacing the water pump look to be straight forward but I can't find the spec for torque on the bolts. It would be great to get them for the thermostat housing and the water pump if anyone has the them. Thanks.
Pump:
There is also a tightening sequence... ..3 1 5 6 4 2 .. 7 Step 1 - 89 in-lbs Step 2 - +45 degree turn Over tightening will damage the pump. Thermostat Housing: ..1 2 3 4 Step 1 - 71 in-lbs Step 2 - +45 degree turn |
Torque
That seem really high for aluminum.
Here is what other told me the service manual has "My Chiltons manual shows 12-18 ftlbs also for the water pump bolt torque.The wp pulley to hub bolt torque is shown as 36-47 ftlbs." Do you have a picture of the screws numbering? I normal would tighten in cross patterned. Thanks again for the advance. Did you get the torques from a Ford Service manual? |
Originally Posted by golfster
(Post 8635033)
Here is what other told me the service manual has "My Chiltons manual shows 12-18 ftlbs also for the water pump bolt torque.The wp pulley to hub bolt torque is shown as 36-47 ftlbs." Do you have a picture of the screws numbering? I normal would tighten in cross patterned. Thanks again for the advance. Did you get the torques from a Ford Service manual? So if you convert 89 in lbs = about 7.4 ft lbs. , which would make the numbers you posted a bit high. |
Torque
I did not notice that. Thanks for point that out.
Anybody have a link to show the numbering of bolts? Plus there is video that show using RTV. Should I use RTV on both side of the gasket? When I read the forum I see both yes and no. Thoughts? I tend to use it when there isn't already a rubber seal. In this case the gasket has a rubber seal. |
I showed the numbering of the bolts the best I could, the ones on the TOP
and the ones on the bottom, of the pump, and their order. Same with the thermostat housing. I got that from my Chilton's manual, but here: PUMP: https://cimg0.ibsrv.net/gimg/mustang...ce3d2ba1d1.jpg T-STAT HOUSING: https://cimg9.ibsrv.net/gimg/mustang...def544049e.jpg |
Thanks a ton for the information!
