where to find roller block 351
RE: where to find roller block 351
94-96 F-150's used 351w roller capable blocks. 94-95 Lightnings were roller caqpable but, had flat tappet cams. E-series vans from the same years are roller also.
It is easy but, depending on what parts you use it can be pretty expensive. DO NOT use the factory roller hardware and tap holes in the lifter valley! Bad idea!
you can find them in these vehicles between 94-95but im not sure about the 96-98 f-code but im sure they are rollers as well. Cobra R, Lightning, F250 F350 and Econoline Vans
09-08-2015 05:21 PM
